FINALLY!!!!!!!!!!!!!!!!!!!!!!!!! New buildup inside!
Old Mar 1, 2008 | 06:22 PM
  #31
mdacton's Avatar
Originally Posted by Kraest
Good springs will last tens of thousands of miles. I don't believe the hype of changing springs every 15-20k on an aftermarket cam buildup... It's a hydraulic roller afterall and this isn't 1930 when cars needed a full rebuild after 15,000-20,000 miles.
with a weak cam like the one kraest has no need to worry if everything is set up right.
Old Mar 4, 2008 | 05:53 PM
  #32
Greed4Speed's Avatar
I don't believe there is a magic point where the springs go bad either, but I can also see where more agressive lobe profiles will wear springs down quicker even with springs designed for the lift.
Old Mar 4, 2008 | 05:57 PM
  #33
Kraest's Avatar
Retired
Of course... the more power = the more wear on the motor... That's why you get a nasty set of springs The lobe profile is somewhere in between an XE-R and an LSK.
Check out my vids in the other thread to see how the cam responds to the go-go pedal.
Old Mar 4, 2008 | 06:25 PM
  #34
LS1Kid717's Avatar
that is an awesome setup
Old Mar 12, 2008 | 01:53 PM
  #35
jmmullin's Avatar
just curious, but in your first post you mentioned the car pulls all the way to the 6800, and later said that peak hp/tq occur around 62-6300; does tuning the car after the cam swap, (and in my case what will be a cam/head swap) help you determine what the redline for the engine should be and what the rev limiter is set at?
Old Mar 12, 2008 | 02:44 PM
  #36
Kraest's Avatar
Retired
The shift points on any car should be a few hundred RPM after the car makes peak horsepower... and sometimes even more as long as the car is still making the same amount of power and hasn't severely dropped off.
Mike
Old Mar 12, 2008 | 03:46 PM
  #37
jmmullin's Avatar
but how do you determine its safe to run the engine that fast on the stock bottom end after doing the modifications? is anything different? just dont want to blow the engine up after doing the work...obviously..
Old Mar 14, 2008 | 03:13 PM
  #38
Kraest's Avatar
Retired
As long as you have the years with the good rod bolts, you will be fine.
Mike
Old Mar 14, 2008 | 03:14 PM
  #39
JakeRobb's Avatar
Super Moderator
Which years are those?
Old Mar 14, 2008 | 03:29 PM
  #40
Kraest's Avatar
Retired
To my knowledge, the cars that came with the 241 heads also came with the better oil pump and rod bolts. Some 2000 cars, but all 01+.
Mike
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
