Factory Freak?
Old Jan 7, 2005 | 09:40 AM
  #61
AL SS590 M6's Avatar
Moderator
Re: Factory Freak?
Originally Posted by robvas
The math can't lie unless your data #'s are wrong
Yep and trying to figure gearing from tach, speedo, tire height is only accurate IF the computer has been reset for the new gears, and you use actual measured rolling radius of the tires instead of manufacturers advertised diameter.
For instance if you were to take a 3.23 geared car and throw a 3.42 rear under it without flashing the 'puter, drive it down the road logging the speedo and tach and you'd calculate that it has 3.23 gears. Now if you used a radar gun to capture actual speed versus the tach readings you'd then calculate that it has 3.42 gears.
Novo
Jun 14, 2016 02:58 AM
magman
Apr 15, 2016 03:08 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
