2000 SS M6 -- Duhh: Where is the PCV?
Old 06-25-2008, 10:26 AM
wrnchbndr's Avatar
At the front of the engine and part of the intake manifold right behind the throttle body on the passeger side is a hose connection. The rubber hose connected here is about four inches long. Pulling off the section of rubber hose reveals an inline fitting that look like a PCV valve end but the rest of this metal contraption is covered in an insulating rubber There is also what seems to be a ground wire connected to this. About three inches further the hose becomes a rigid plastic tube. Is this my PCV? And, does it just pull off of the rigid plastic tube? -- I don't want to break anything. I have the dreaded LS1 high oil consuption with no puddle and no smoke. I want to change the PCV and install a catch can.
wrnchbndr is offline
Old 06-25-2008, 04:31 PM
super83Z's Avatar
Whatever you described that looks like a PCV valve is it. Just pull it out.
super83Z is offline
Old 06-25-2008, 10:28 PM
Red89GTA's Avatar
Pictures? show us what you are talking about, it'll make it an easier diag, but what it sounds like is the pcv. Put a breather there and smile.
Red89GTA is offline
Old 06-26-2008, 06:40 AM
Moderator
AL SS590 M6's Avatar
Yep that's the PCV valve. The ground wire clips around the body of the valve and the valve just pulls out of the insulation and tube that it's plugged into.
AL SS590 M6 is offline
Z28ELECTRICIAN
10-19-2015 06:36 AM
68camaroboltz
10-05-2015 11:56 PM
drt
09-27-2015 04:39 PM
pepon214tx
09-20-2015 04:48 PM
scottcba1
09-08-2015 09:52 AM
Quick Reply: 2000 SS M6 -- Duhh: Where is the PCV?
