wrnchbndr |
06-25-2008 10:26 AM |
2000 SS M6 -- Duhh: Where is the PCV?
At the front of the engine and part of the intake manifold right behind the throttle body on the passeger side is a hose connection. The rubber hose connected here is about four inches long. Pulling off the section of rubber hose reveals an inline fitting that look like a PCV valve end but the rest of this metal contraption is covered in an insulating rubber There is also what seems to be a ground wire connected to this. About three inches further the hose becomes a rigid plastic tube. Is this my PCV? And, does it just pull off of the rigid plastic tube? -- I don't want to break anything. I have the dreaded LS1 high oil consuption with no puddle and no smoke. I want to change the PCV and install a catch can.
