Window Works Intermittently
Old Apr 30, 2004 | 09:17 AM
BigED's Avatar
My driver's side window just started having a problem where is doesn't work properly. When I push the button to make it go down/up it only goes about 3-4 inches and then stops. If I push the button again in either direction it gets nowhere. If I then wait about 30-60 seconds, and push the button again, I have the ability to move it another 3-4 inches It's like the motor only works for a little bit and then gets tired, and was it can catch its breath it is able to move again. I'm trying to figure out the logic behind what could be causing this.
The window has done this maybe 3-4 times in the past over the last 3 months, but now it consistently behaves like this. I've read a lot of posts about these motors dying in older cars, but my car is a 2002! How could it break already?
Old Apr 30, 2004 | 11:19 AM
Brent94Z's Avatar
Super Moderator
Window motor is shot
You'll need about $50 and this page
http://shbox.com/page/windowmotor.html
Old Apr 30, 2004 | 11:36 AM
Ron78Z&01SS's Avatar
Yeah, what Brent said.
The motor has an internal self-resetting circuit breaker. After it cools down it resets itself. It's inside the motor and can't be repaired.
Old Apr 30, 2004 | 12:28 PM
david97gsxr's Avatar
oh, but it can be repaired
Old Apr 30, 2004 | 12:58 PM
MysticTeal 95 V6's Avatar
It's pretty easy to change out the motor for the windows... I was a little intimidated at first to tackle the project on my Camaro but once I got the door panel off and followed the How-To online, it was very simple
I know how irritating it can be for the windows to not go up/down when you want them to.
Old Apr 30, 2004 | 08:35 PM
GreenDemon's Avatar
Wow your symptoms are like a quote from a web page.
As for why your window motor already went out...
GM has never been known for good electrical equipment. 90% of the problems with these cars are electrical in nature. It's pretty much the opposite of an import. GM folks replace some sensors, import folks replace a head gasket...
Red Hawk 94
Mar 18, 2019 04:03 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
warmeck
Feb 2, 2015 12:44 AM
Collector Car
Jan 5, 2015 10:58 AM
Injuneer
Dec 15, 2014 09:36 AM
