Window regulator
Window regulator
My window regulator rivets that hold it to the door are rea loose and one is cracking out. Can I drill them out and replace them with bolts or do they need to pivot? What's the fix? Thanks.
If the contact point where the rivit was is cracked use a fender washer there to spread out the load. I had the same problem with mine. This prevents additional damage and keeps the bolt head from pulling through the hole.
Warren
Warren
68camaroboltz
Oct 5, 2015 11:56 PM
z28cam1993
Sep 9, 2015 04:08 AM
