Window regulator
Old Aug 19, 2008 | 05:02 PM
RUDEDOG's Avatar
Window regulator
My window regulator rivets that hold it to the door are rea loose and one is cracking out. Can I drill them out and replace them with bolts or do they need to pivot? What's the fix? Thanks.
Old Aug 19, 2008 | 05:24 PM
Bolts will work as long as they do not interfere with operation.
Old Aug 19, 2008 | 05:57 PM
Warren_Seale's Avatar
If the contact point where the rivit was is cracked use a fender washer there to spread out the load. I had the same problem with mine. This prevents additional damage and keeps the bolt head from pulling through the hole.
Warren
Old Aug 19, 2008 | 08:34 PM
RUDEDOG's Avatar
Thanks guys. Good ideas.
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
