Wheel fit ?
Old Jun 17, 2004 | 05:59 PM
Dave89IROC's Avatar
Wheel fit ?
Will these wheels fit on a 94 Z28?
what size tires?
Old Jun 17, 2004 | 06:01 PM
Dave89IROC's Avatar
or should I just get a set that are 9 1/2 wide all around?
Old Jun 17, 2004 | 06:40 PM
n2ceptor's Avatar
If you post in the Wheel and Tire section you will prob get a better response.... I believe there was a thread on these rims, and some people had them on their F-bodies...
Old Jun 17, 2004 | 10:52 PM
sick94's Avatar
i'm pretty sure that they will bolt right up w/out any problems. however if you want to rotate your tires then i would go 9.5 or 10 all way round cuz w/ 11's out back and 9.5's in front is impossible. l8tr,
Old Jun 18, 2004 | 11:58 AM
Those wheels are the correct "offset" for the 4th Gen. You may need some work in the rear to fit the 17x11" wheels - depends on the tires.... some 315's are wider than others. Sometimes requires cutting the jounce bumper brackets back a little, hammering the inner fender liners, or recentering the body over the axle with an adjustable panhard rod.
You should really use the "Wheels & Tires" forum.....
mschmidt33
Mar 15, 2015 07:20 PM
Moshbmx1
Jan 20, 2015 03:27 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
Dec 4, 2014 11:56 AM
