Wheel fit ?
i'm pretty sure that they will bolt right up w/out any problems. however if you want to rotate your tires then i would go 9.5 or 10 all way round cuz w/ 11's out back and 9.5's in front is impossible. l8tr,
Those wheels are the correct "offset" for the 4th Gen. You may need some work in the rear to fit the 17x11" wheels - depends on the tires.... some 315's are wider than others. Sometimes requires cutting the jounce bumper brackets back a little, hammering the inner fender liners, or recentering the body over the axle with an adjustable panhard rod.
You should really use the "Wheels & Tires" forum.....
mschmidt33
Mar 15, 2015 07:20 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Dec 4, 2014 11:56 AM
