Wats wrong??
Old Jul 5, 2005 | 10:24 PM
1crazylt1's Avatar
Wats wrong??
Ok every time i go to start my car i need to give it gas to start..does anyone no y this is?
Old Jul 6, 2005 | 05:27 AM
teke184's Avatar
Re: Wats wrong??
bad opti, bad plugs, bad wires, bad fuel pump, bad gas, bad sensor.....
could be many things.
does the SES light come on? have it scanned that will likely get you going in the right direction
Old Jul 6, 2005 | 08:47 AM
1crazylt1's Avatar
Re: Wats wrong??
i just got my opti,plugs,wires done like a month ago..far as gas i onli put sunoco ultra in it...
Old Jul 6, 2005 | 01:41 PM
Re: Wats wrong??
What do you actually do when you "give it gas"? Putting the pedal to the floor puts the PCM in "clear flood" mode.... which might point to a problem, if that's what you have to do. Putting the pedal partway to the floor will increase air flow and clear out accumulated fuel, but not as dramatically as putting it all the way to the floor.
Old Jul 6, 2005 | 03:17 PM
1crazylt1's Avatar
Re: Wats wrong??
i pump the gas wen i go to start it
Old Jul 6, 2005 | 04:27 PM
teke184's Avatar
Re: Wats wrong??
just because they are new doesn't mean they are not the problem.
factory fresh parts can still fail, inproper installation, plug wire burned....
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
