Vats question
Old Jan 14, 2006 | 01:28 AM
smoknta's Avatar
Vats question
I am currently gutting my 93 TA. Just got rid of all the HVAC stuff and also all the power options. I am currently in the process of pulling all the unused wiring now. The one I am not sure about is the vats box.
Now I know you can program the vats function to be off in the program, but is the box still needed?
Old Jan 14, 2006 | 05:24 AM
oneslowz28's Avatar
Re: Vats question
good question i would post about this in the programing section as there are alot of programers in there
Old Jan 14, 2006 | 10:31 AM
Re: Vats question
Shoebox has a VATS bypass wiring diagram. That would eliminate the wiring to the steering column. Wouldn't eliminate the box though:
http://shbox.com/1/vats_bypass.jpg
Old Jan 14, 2006 | 01:27 PM
smoknta's Avatar
Re: Vats question
I'm wanting to get rid of everything. If the programming wont do it. I think I can just get rid of it by giving the pcm a constant fuel and ignition permissive feed. Just thought I would see if anyone has done it.
Old Jan 14, 2006 | 11:19 PM
Re: Vats question
I would think that programming it out of the computer would keep you from having to fake the signal from the VATS module to the computer. The VATS module cares about the key reading and the computer cares about what the VATS tells it. The computer doesn't care about the key reading (directly).
Old Jan 15, 2006 | 06:23 AM
Dave89IROC's Avatar
Re: Vats question
you would need to do something about the theft deterrant relay as well, but yes, you can get rid of it
remember, on a 93 it takes a chip, so, get it tuned out of the chip
Old Jan 15, 2006 | 08:44 AM
smoknta's Avatar
Re: Vats question
Tuning isn't a problem, I have all the stuff to do that. I just wasn't sure what all disabling the vats in tuning would do. Thanks for the help.
Klypto
Mar 9, 2015 04:25 PM
Noer
Feb 28, 2015 11:29 AM
Lakebratt
Feb 5, 2015 07:55 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Fedesna
Nov 23, 2014 11:06 AM
