Tranny Fluid in coolant
Old Apr 25, 2011 | 10:05 AM
Shane97Z28's Avatar
Hey guys I just bought a 97 Z. I thought it was running hot so I took it to have it looked at and they said I have transmission fluid in my raditor and that it needs a new water pump. I was gonna attempt to replace the radiator and water pump myself. But how would I go about flushing out that tranny fluid ? And do I need to have my transmission flushed out now as well ? The car has 43k miles on it. They wanna charge me 1100 bucks to fix the problem is that fair or can I do this job myself and be able to get that tranny fluid out. Thanks for any advice
Old Apr 25, 2011 | 11:41 AM
19z28camaro02's Avatar
Re: Tranny Fluid in coolant
A shop is going to have to perform the tranny flush. They have a machine that will completely flush the fluid till it becomes clear.
Old Apr 25, 2011 | 11:58 AM
redneckgames's Avatar
How much mechanical experience do you have?
The waterpump and radiator you should be able to do yourself.
Trans flush should be done by a shop.
$1100 to me is crazy.
Old Apr 25, 2011 | 02:59 PM
Shane97Z28's Avatar
Thanks guys I just ordered all the parts gonna try and do it. The car is running way to hot about 245 is that most likely due to the tranny fluid in the coolant or do I have yet another problem maybe ?
Old Apr 26, 2011 | 02:04 PM
brian12's Avatar
I wouldn't drive it around if the coolant gets in your tranny it will ruin it.
Old Apr 26, 2011 | 07:17 PM
leadmonster's Avatar
instead of replacing the radiator it might be cheeper to flush it out and also the trans lines in the radiator cap them off and run it like that. use external trans cooler.
blac94Z
Feb 15, 2021 09:43 PM
FieroLT1
Jun 26, 2015 08:43 PM
jmadoll
May 27, 2015 07:13 PM
91 Redd Sledd
Aug 25, 2002 03:27 PM
rncotton
Jul 1, 2002 10:43 PM
