Tie Rods, Easy to remove from steering rack?
Old May 24, 2013 | 12:36 PM
95WhiteZ28LT1's Avatar
Ok so heres the scoop. The car was in a bit of an accident, and the steering rod and end snapped right off the knuckle so i was wondering. Instead of just getting a whole new rack, is it easy to just remove one of those rods? Driver side if that makes any difference.
Any and all help is appreciated, going to get parts tmrw and dont want to buy the whole rack if i dont have to.
Old May 24, 2013 | 01:41 PM
Re: Tie Rods, Easy to remove from steering rack?
Everything pretty much unscrews - unscrew outer tie rod, remove boot (requires boot clamp tool to crimp new clamp on), unscrew inner tie rod. But the factory manual indicates you have to remove the rack to get the inner tie rod off the rack assembly, and the rack teeth have to be stabilized to prevent damage.
Might be best to pull the rack, and take it to a shop that has the right tools.
Old May 24, 2013 | 02:04 PM
All tools needed are in my shop, not a problem. and i did read that it needs to be stabilized but everyone else has said they have done it without issue not stabilizing it.
Victor Lamb
Aug 26, 2017 02:52 PM
Jun 6, 2015 08:27 AM
Richardan15
May 30, 2015 08:36 AM
mspennyhughes
Mar 1, 2015 03:50 PM
Hurin
Dec 13, 2014 07:38 PM
