Swap lt1 from a 94 to a 97
Old Aug 2, 2020 | 01:38 AM
Edmaro17's Avatar
Hello guys. I need help to understand the situation.
So I bought a z28 1997 camaro with a broke engine. I had a 94 camaro so I decide to put the 94 LT1 in the 97 z28 .
So it start awesome. But after 10 minutes the engine start to sounds bad and move like a crazy damm engine.
the transmission only gave me 2 speeds no more.
My question is. Is there any problem with the computer?
or its because it have headers and still cant install the pipe with the oxygen sensors.
What I need to do here?
thank you
Old Aug 2, 2020 | 11:11 AM
Re: Swap lt1 from a 94 to a 97
Which year 4L60E transmission are you using? Which year PCM are you using? Which year engine harness are you using?
The 94 engine does not have a crankshaft position sensor for misfire detection. The 94 does not have an EVAP vacuum switch. The 97 harness connector will not connect correctly with a 1994 Opti, the connectors are different lengths. How did you address all those differences?
You can’t control a 94 4L60E with a 1997 PCM, You can’t control a 97 4L60E with a 1994 PCM.
The 94 engine uses a different knock sensor than the 97. The knock sensor and the PCM have to be from the same year, or you will get almost constant knock retard = power loss.
PCM can’t control the A/F ratio without the pre-cat O2 sensors.
eworkman95
Oct 6, 2018 11:31 AM
cmdeshon
Jan 4, 2015 11:15 AM
mvvette97
May 24, 2009 06:34 PM
Phantomhp
Apr 9, 2007 11:10 AM
chiselmonkey
Jun 21, 2003 10:03 AM
