SES Code 29
Old Oct 17, 2006 | 03:09 PM
sandman63's Avatar
SES Code 29
Hey, my SES light just came on, an i put the scanner on it, an its Code 29? Does anyone know what that one is? an how i should go of fixing it, thanks.
Old Oct 17, 2006 | 03:43 PM
2001NBMZ28's Avatar
Re: SES Code 29
Don't know how to fix it but you can look it up at http://shbox.com/1/Dtcs.htm
Old Oct 17, 2006 | 05:51 PM
Re: SES Code 29
99% of the time, its due to a blown fuse for the AIR pump. Replace the fuse. If it continues to blow, disconnect the harness connector from the AIR pump, and then put the new fuse in. The SES light will go out. Of course the AIR pump won't work, but there's not much impact except more emissions on a cold start.
Old Oct 17, 2006 | 05:53 PM
sandman63's Avatar
Re: SES Code 29
Dumb question, but where is the fuse located?
Old Oct 17, 2006 | 08:45 PM
2001NBMZ28's Avatar
Re: SES Code 29
No owners manual? Also on Shoebox's site - http://shbox.com/pdf/manuals.html
Old Oct 17, 2006 | 08:53 PM
sandman63's Avatar
Re: SES Code 29
Yea, after asking that question, i just looked in the owners manual an that told me, tho, i did replace the fuse with the proper one, an well it blew twice already. So how do i go of removing the AIR pump? An once i do, will the SES light always be on an if so, how do i remove it so it wont come back again?
Old Oct 17, 2006 | 09:03 PM
Dave89IROC's Avatar
Re: SES Code 29
just unplug the pump and then put a fuse in it, youl'll be good to go
Old Oct 17, 2006 | 11:30 PM
sandman63's Avatar
Re: SES Code 29
Hey thanks dave, tho if i wanted to physically take it out, hard job or not? worth it?
Old Oct 18, 2006 | 06:23 AM
Dave89IROC's Avatar
Re: SES Code 29
a 3 bolts holding the pump to the bracket, 3 bolts holding the bracket to the engine, some rubber hoses, a metal tube, then you need to cap the holes in the exhaust manifolds
worth it if you want the room/clean up the engine bay, otherwise, no
Old Oct 18, 2006 | 11:21 AM
sandman63's Avatar
Re: SES Code 29
Thanks once again Dave. I plan on doing a header intstall in the future, i just do it then.
Old Oct 18, 2006 | 02:28 PM
sandman63's Avatar
Re: SES Code 29
Where do i unplug it from?
Old Oct 18, 2006 | 05:45 PM
Re: SES Code 29
There's a harness connector plugged into the side of the AIR pump. You unplug that connector.
BigED
Jun 23, 2015 07:19 PM
Hannibal
Sep 10, 2002 04:25 PM
Hannibal
Sep 6, 2002 05:07 AM
lax037
Aug 18, 2002 02:07 PM
91Bird305
Aug 5, 2002 01:39 PM
