Panel removal help on a 94 Camaro
Old Apr 22, 2011 | 08:47 AM
acct91438's Avatar
Hi guys,
i don't know how you call that cover thats troubling me, so please see this pic
http://img18.imageshack.us/img18/635...camarointe.jpg
Can somebody please tell me how this cover is a, called and b, removed/where its fixed?
I first thought that its just clipped to the dashboard and fixed with screws on its the covers bottom behind the radio bezel but i must be wrong
thanks in advance
Old Apr 23, 2011 | 09:55 AM
Re: Panel removal help on a 94 Camaro
The large piece surrounding the gauges and vents is the "bezel, instrument cluster trim plate". There area a total of 5 screws/pins that hold it on. From my Chilton's, the bolt/pin locations, and the correct order for installing/tightening them is (viewed from the driver's seat):
1 - Upper left surface, back from the right edge of the left A/C vent
2 - Upper right surface, back from the left edge of the right A/C vent
3 - Lower left side, under the right edge of the headlight switch
4 - Lower right side, under the left edge of the HVAC panel
5 - Lower left corner, bolt head faces the door panel
I think on the Camaro you need to pull the big, flat upper trim panel up to acces the top of the bezel. Be careful, because it is VERY easy to crack the flat panel, and hard to find a replacement. You may also have to remove the knee bolster.
Alien
West South Central
Jan 11, 2015 12:51 PM
siguy
Nov 27, 2014 10:07 AM
yosshimura
Aug 14, 2002 07:29 PM
Zomie
Jul 25, 2002 07:52 AM
