open headers
open headers
i have heard people talking about wanting to run open headers but something to do with your engine taking a breath will bend pushrods or something? can someone please explain it to me
-Dakota
-Dakota
Re: open headers
Personally, I haven't heard of such a thing happening, maybe someone would care to enlighten me. I have, however, heard, that running open headers could cause weird driveabililty conditions if outside air contacts the 02 sensors, which run very close to the end of the headers.
Re: open headers
I know, I will never forget the look at the rednecks face in a big "loud" pickup next to me when I was just idling....then to see it when I berlay took off in first was just priceless.
Re: open headers
Originally Posted by flatlander757
Anyone within 1/2 mile of you will think the world is coming to an end
AMEN!
Re: open headers
Originally Posted by 00cls1camaross
so what is the deal with your car taking a breath
And if there was damage, its not likely you would "bend pushrods". With a carb setup, opening up the headers and not adjusting the fuel might cause it to run lean and burn the valves. But with a computer controlled fuel injection system, the computer will correct the air/fuel mixture when you improve the engine's "breathing".
As noted in several posts above, you can get into trouble with a computer controlled system if the O2 sensors are in the header collectors, close to the open end - and that's where they usually are. The air mixes with the exiting exhaust, the O2 sensors think its running lean, and the computer pours in extra fuel, causing the engine to run excessively rich.
carguyshu
Jan 22, 2017 11:19 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
jasonduaine
Apr 1, 2015 08:09 PM
