OBD-I computer not control OBD-II car's A/C system?
Old May 28, 2011 | 11:04 AM
Dave88LX's Avatar
1997 Firebird, converted from OBD-II to OBD-I.
After getting the car back together, took it to get an alignment and my rotors turned. While I was there I asked about the A/C. They tested my system, said it held a vacuum, and that it could be filled. Had them fill it.
They said it wouldn't turn on unless they grounded the relay, and asked if I had an aftermarket computer. Sort of. OBD-I in there.
Is there something in the OBD-I computer that is missing to kick on the A/C relay? Or is this known, and I have to run the A/C off a toggle switch?
Thank you.
Old May 28, 2011 | 11:29 AM
Re: OBD-I computer not control OBD-II car's A/C system?
There is no difference in a/c operation that I am aware of. Check for the presence of an a/c code. It has to be cleared (or PCM reset) to allow compressor operation.
Old May 28, 2011 | 12:59 PM
Dave88LX's Avatar
I have this code:
71 a/c evaporator temperature sensor circuit low
That's probably it then? I ***umed I had that code because I didn't have a freon charge.
I feel dumb asking how to clear it, as long as I've been here.
Old May 28, 2011 | 01:38 PM
Originally Posted by Dave88LX
I have this code:
66-69 will disable a/c operation, but it does not say 71 will. Reset the PCM by pulling the PCM BAT fuse for about 30 seconds.
The evaporator sensor is on the evaporator coil under the dash.
Old May 31, 2011 | 08:41 PM
Dave88LX's Avatar
Thanks Rob I will give that a shot. Hopefully it takes care of it.
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
CobraEatr
Jul 29, 2002 11:46 AM
Absolute Z28
Jul 19, 2002 02:21 PM
