Monsoon Front Speakers
Old Jun 27, 2018 | 09:43 AM
Fordication's Avatar
So I sent the car stereo out and they had to put a new board in it. It worked but as soon as I turned it on the front right speaker was rattling. I bought a set of infinity 2 ohm coaxial speakers to replace it only to find that the original speaker has 4 wires. 2 for the tweeter and 2 for the woofer. I suspect that means that the amp works for the woofers only which means that is why the car has way too much bass distortion. So what did everyone else do. I can separate the tweeters on the speakers but I really do not want to. What should I do? Yes, I have seen the video on doing that but it seems like a bad idea. Remember, I am trying to keep the car as stock as possible but the truth is those front speakers were crap from the factory.
Old Aug 22, 2018 | 07:04 PM
Re: Monsoon Front Speakers
Anyone. I have seen the video on how to separate the mids from the tweeters. Only question is that the new speakers have a built in cross over. Do use the built in crossovers or not.
Old Aug 23, 2018 | 08:56 AM
GaryDoug's Avatar
Prominent Member
Separate the speakers and remove the crossovers. The amp drives both mids and tweeters.
Old Aug 23, 2018 | 10:12 AM
However the crossovers protect the tweeter. So I need to bypass the crossovers. I assume the crossovers are the set of capacitors inline?
Old Aug 23, 2018 | 10:46 AM
GaryDoug's Avatar
Prominent Member
Yes
Old Apr 24, 2019 | 09:21 AM
buzzsaw's Avatar
I need to replace the front speakers in my 2000 Camaro SS - would like the original "plug and play" - anyone know where I can buy them ?
Old Apr 24, 2019 | 09:56 AM
GaryDoug's Avatar
Prominent Member
Not available anywhere as new. You may find some used ones on eBay. Match the part number on yours.
Other options:
1. Try to get a compatible speaker (2 ohms) from another speaker company. I tried Infinity and was disappointed with their 3.2 Ohms ones.
2. Repair yours by using a surround repair kit. https://www.speakerworks.com/speaker...-kits-s/65.htm
Old Apr 24, 2019 | 10:55 AM
buzzsaw's Avatar
Other options:
Thanks - I already did the passenger side (ebay) - how can I get the model (without ripping off the panel) of the drivers side to search for it ?
Old Apr 24, 2019 | 01:21 PM
GaryDoug's Avatar
Prominent Member
The ones in my 98 TA are 09370219 but I seem to remember there being some replacement part numbers.
68-97camaro
Dec 25, 2006 01:23 PM
InTeNsE
Aug 27, 2003 04:16 PM
383 Smoka
Jul 21, 2003 09:31 AM
ucrazymonkey
Mar 25, 2003 12:01 AM
galivan
Jan 15, 2003 05:42 AM
