Inside fuel tank
Inside fuel tank
Hey guys so last year i replaced my Fuel pump bcuz i thought it was bad,my gauge is on the full mark,i noticed it hasnt moved only after i shut off the car the needle will move down a lil bit. Im not sure if i installed it correctly with the floater to where my gauge is showing the right fuel. Can some tell me how do i install it the correct way to where the it will read my gauge right. The pic in the thread im not sure if theres enough fuel. Bcuz my car sputtered n died. Pressure was at 5
Re: Inside fuel tank
Attached is a diagram from the 1994 factory service manual (FSM) showing the fuel sender assembly in its correct orientation. You can download a free copy of the manual, courtesy of GaryDoug:
http://www.mediafire.com/?40mfgeoe4ctti
Shoebox has a good guide to troubleshooting problems with the fuel gauge:
There are an awful lot of cheap Chinese counterfeit fuel pumps on the market. Not unusual for a rapid failure if you get stuck with one of those.
4th Gen LT1 F-body Tech Articles
oneslowz28
May 5, 2005 06:10 AM
