I am a new camaro owner and need help
Old Jun 17, 2011 | 04:11 PM
Johnny111444's Avatar
I found a V8 lt1 engine with 72k miles on it for $550 and I am going to buy it if i can find a computer and harness. Does anyone know where i can find a cheap wiring harness or computer for the 5.7 v8.
Old Jun 17, 2011 | 04:19 PM
rv93's Avatar
Re: I am a new camaro owner and need help
good luck finding the harness. but just so you know, they didnt have an lt1 in 88. they put them in vettes in 92, and camaros in 93.
Old Jun 17, 2011 | 04:52 PM
Originally Posted by Johnny111444
I just bought a 93 camaro with a V6 with a bad piston bearing and a tranny that won't shift over second. The motor has 158,000 miles on it so I went looking for a new motor. I found a V8 lt1 engine with 72k miles on it for $550 and I am going to buy it if i can find a computer and harness. the motor is coming out of a 86 camaro. I just found a 1995 z28 camaro with no engine, tranny, or wiring so i figured that, that car would be a better because it has a posi rear axel and ttops. I need help finding a cheap egine harness and computer any help will be thankfull.
Confusing - you found an LT1 in an 86 Camaro? No 3rd Gens had the LT1, so it must be a transplant. What year is the LT1? Make a difference - 93 has major differences from other years, 94 is OBD-I with the unvented Optispark distributor, 95 is OBD-I with the vented Opti, 96/97 is OBD-II with the vented Opti and a different knock sensor.
Then it appears you are abandoning your 93 completely, and using the 95 Z28 for the LT1 install. That make a lot more sense, because you can't just drop an LT1 into the V6 chassis. You would need a new K-member, a different trans and a different driveshaft, plus upgrades on the front springs for the extra weight.
Might want to clarify the year of the engine.
Old Jun 17, 2011 | 05:14 PM
Well the person i talked to told me it came out of an 86 camaro. It is a guy who only sells engines by me. That is the last one he has and it is only the engine no wires tranny or computer but i can get a tranny easliy but i cant find a computer or wiring harness. I have a tight budget but can spend about $300 on the wiring and the computer.
Old Jun 17, 2011 | 06:29 PM
moparman's Avatar
Better double check that it is an LT1.
Old Jun 17, 2011 | 06:34 PM
It may not be but it is a 5.7 v8 for sure
F'n1996Z28SS
Aug 23, 2023 11:19 PM
bernie1951
Dec 10, 2014 10:03 AM
Dec 4, 2014 11:56 AM
carcrazyQT
Sep 3, 2002 02:51 PM
