I am a new camaro owner and need help
I found a V8 lt1 engine with 72k miles on it for $550 and I am going to buy it if i can find a computer and harness. Does anyone know where i can find a cheap wiring harness or computer for the 5.7 v8.
Re: I am a new camaro owner and need help
I just bought a 93 camaro with a V6 with a bad piston bearing and a tranny that won't shift over second. The motor has 158,000 miles on it so I went looking for a new motor. I found a V8 lt1 engine with 72k miles on it for $550 and I am going to buy it if i can find a computer and harness. the motor is coming out of a 86 camaro. I just found a 1995 z28 camaro with no engine, tranny, or wiring so i figured that, that car would be a better because it has a posi rear axel and ttops. I need help finding a cheap egine harness and computer any help will be thankfull.
Then it appears you are abandoning your 93 completely, and using the 95 Z28 for the LT1 install. That make a lot more sense, because you can't just drop an LT1 into the V6 chassis. You would need a new K-member, a different trans and a different driveshaft, plus upgrades on the front springs for the extra weight.
Might want to clarify the year of the engine.
Well the person i talked to told me it came out of an 86 camaro. It is a guy who only sells engines by me. That is the last one he has and it is only the engine no wires tranny or computer but i can get a tranny easliy but i cant find a computer or wiring harness. I have a tight budget but can spend about $300 on the wiring and the computer.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Dec 4, 2014 11:56 AM
