How to turn Off Service Engine Soon Light?
Hi Guys,
My SES light is on. I've been looking for an article describing how to turn it off. I'm thinking there must be some way to turn it off relatively painlessly?
Does anyone know how to disable SES light?
Edit: 1997 LT1 Firebird Formula
Thanks!
Ivan
Thanks!
Ivan
Re: How to turn Off Service Engine Soon Light?
Find out what is causing it and fix it. You will need to pull the trouble codes, and fix/replace the appropriate part or whatever is causing the problem. Depending on what year your car is, autozone may be able to retreive the trouble codes for you.
Originally Posted by moparman
Yeah, that P0300 can be a real bear to track down.
Originally Posted by ivanisui
Thanks so much for the responses.
Do you know how I can disable the light so that it doesn't go on without fixing the codes?
Thanks!
Ivan
Thanks!
Ivan
I'd have the code(s) read, write it down so you won't forget, ask them to clear it. Post the code(s) if the light comes on again after another scan, might be something easy, might even be throwing more than one code...I've thrown P0300 a couple times over the years, and just reset it.
Even if you turn the light off, it will come back on unless whatever caused it is taken care of. It's best to go ahead and take care of the problem, because it could be something that could cause more problems and cost mo money. Get the codes pulled and post them here. We'll try and help.
Thanks!
Ivan
Thanks!
Ivan
Your call.
One more thing, if you have inspections, you fail automatically if that SES light doesn't come on during that dash light test when the inspector turns the key before starting the car up.
Since I only use the stock PCM for the speedo and idle air control and there are a bunch of things like the injectors, MAF, knock sensor, etc that are no longer connected to it, I simply removed the wire from pin D9 of the PCM.
I'd agree with others though.... if you're still running the stock PCM, it makes sense to keep the light connected, and correct the problem.
you can always disconnect the battery for a minute and then reconnect it. it will clear the PCM and your engine light will turn off. but as soon as the computer picks it up again the light with come back on. Best bet is to find out the problem and get it fixed.
ro2207
Dec 4, 2014 06:18 PM
mspennyhughes
Nov 28, 2014 03:22 PM
