Header Bolt recommendations
Old Oct 26, 2010 | 01:05 PM
The Captain's Avatar
Putting my headers on in a couple weeks, need to know which bolts to get. I am going to use Felpro 1406 gaskets. Headers are MAC Shorties. Thanks!
Old Oct 26, 2010 | 01:49 PM
NJ-LE's Avatar
My MACs came with copper gaskets. I used them and have had no problems with leaks. I used 3/8" x 1" 16 tpi stainless allen socket bolts. I've checked them once in a while but found they're always tight. I think it's important to use 1" long bolts as most leaks seem to happen when using the 3/4" bolts. Also, since the MAC (mine are about 4 years old) headers don't have a one piece head flange the alignment with the exhaust ports could be disturbed by careless handling during shipping. Check it by holding the new exhaust gasket against the flange and adjust if necessary. Use a soft hammer to adjust the socket for the slip fit cylinder #1 tube to be a very snug fit. I used a small band clamp on that tube and some Permatex "Ultra Copper" (#101BR) on the tube before sliding it in. Good Luck.
Old Oct 27, 2010 | 08:42 AM
Procharged94Lt1's Avatar
Def go with the 1" bolts no matter what- using 3/4" bolts you can easily strip the header bolt holes in the head if you aren't careful.
Old Oct 29, 2010 | 12:38 AM
Larsv8's Avatar
I used to the 1 inch stage 8 locking ones with the inserts for allen wrenches. They were really easy to get in. The allen fittings are extremely useful.
Old Nov 4, 2010 | 05:07 PM
zmike's Avatar
Re: Header Bolt recommendations
I bought a set of the ARP 1" with the 5/16" 12 pt head. Will be putting them in with the new motor and a set of Kooks LT. From reading alot of posts they seem to work well and the extra lenght may help to prevent loosening.
Old Nov 13, 2010 | 08:13 PM
Wilson's Avatar
i've had the stage 8 locking bolts in my 93 for the last 10+ yrs. No problems with them backing out from the heat cycles. Just make sure to check them after a few heat cycles to make sure its still on good to prevent leaks.
Victor Lamb
Aug 26, 2017 02:52 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
