Adding extra grounding points like the import guys?
Old Nov 13, 2010 | 06:20 PM
Wilson's Avatar
Talking Adding extra grounding points like the import guys?
Okay i've been trolling on the G35/37 board lately since our other car is a import. Seems like they have seen benefits running extra grounding points throughout the engine bay. Most of them are using 4 or 8 gauge oxygen free copper cables. I wonder if my old 4th gen would see any benefits for doing this as a cheap DIY'er? You can get about 20ft of 8 wire for about $25 bucks. Anyone tried adding extra grounding points and which locations did you use? THanks!
Old Nov 14, 2010 | 10:50 AM
1-bad-z28's Avatar
Re: Adding extra grounding points like the import guys?
What benefits are they seeing? Seems to me that if everything is already grounded, additional grounding points wouldnt do anything.
Old Nov 14, 2010 | 11:45 AM
"oxygen free"? ....... sounds like the audio nuts who claim that the purer the copper wire, the better their systems sound. They are paying $100 - $200 per foot for this stuff, with mutliple strand diameters, braided into wierdo patterns. Here's what Wikipedia says about "OF" copper:
C10200 - also known as Oxygen-Free (OF). While OF is considered oxygen-free, its conductivity rating is no better than the more common ETP grade below. It has a 0.001% oxygen content, 99.95% purity and minimum 100% IACS conductivity. For the purposes of purity percentage, silver (Ag) content is counted as copper (Cu).
C11000 - also known as Electrolytic-Tough-Pitch (ETP). This is the most common copper. It is universal for electrical applications. ETP has a minimum conductivity rating of 100% IACS and is required to be 99.9% pure. It has 0.02% to 0.04% oxygen content (typical). Most ETP sold today will meet or exceed the 101% IACS specification. As with OF copper, silver (Ag) content is counted as copper (Cu) for purity purposes.
Many cables today are advertised as using "oxygen-free copper," copper which has been annealed in an oxygen-free atmosphere. OFC is popular in audio cables, and has begun to make inroads into the video cable market as well.[5]. The merits of OFHC for such applications are, however, minimal.
Many owners of high-end audio and video equipment value oxygen-free copper. Behind this demand is the belief that oxygen-free copper will have enhanced conductivity or other electrical properties that are significantly advantageous to low frequency (audio) signal transmission. However, conductivity specifications for C11000 ETP and C10200 OF coppers are identical. In practice, nominal conductivity differences between the three grades listed above are less than .1% of .1% at room temperature.
If you need more "conductivity", just use a larger wire.
Or... maybe they will be using pure silver next, for even greater results.
Here's the correct braided ground strap material:
http://www.wiringproducts.com/contents/en-us/d80.html
Get a roll of the 3/4" x 1/8" stuff, and have at it.
DirtyDaveW
Dec 1, 2016 05:37 PM
Collector Car
Jan 5, 2015 10:58 AM
hotrodyou1
Dec 20, 2014 10:05 PM
Red97LT1
Aug 7, 2002 05:45 PM
