Fusible links
Re: Fusible links
The fusible links aren't in the fuse box. They are part of the wires attached to the red plastic "+" terminal box on the passenger side inner fender, near battery. One of those supplies 12V power to the fans. The fuse in the under hood convenience box is for the fan control relays.
From Shoebox:
http://shbox.com/1/fusible.jpg
Maybe Rob knows how to tell them apart.
The 94 factory manual indicates it is 1 sq mm "rust" color (the stripe?? - but they are all labeled as rust???).
From Shoebox:
Re: Fusible links
Yea fat dog thanks but i need the links on the left side under hood
and mr.fred thanks i know when i did my head lights i was able to tell them apart by the number of wires come from the fusible link it self
Re: Fusible links
My bad.Anyway,I got a free meter from Harbor Freight on one of their ads when you make a purchase of any amount.Check it out.They have the ads laying around there.I just don't know how to use it so it collects dust.My brother-in-law knows how to use these,I just need some schoolin and patience on it. Hope this helps.
Prominent Member
Re: Fusible links
Locate the link wire pair that shares the same terminal and has two "1.0 SQ mm" links. That pair should have one link for the hvac blower and another for the fans. Confirm that by disconnecting all but that pair from the post and seeing if the blower operates. I can't tell you how to determine which of the two is for the fans.
Prominent Member
Re: Fusible links
Way to go. Wish they would make them easier to trace.
Fatdog2:
That meter you got will probably have at least one bad probe lead. Every one i have gotten has been able to be easily pulled apart from the probe tip. The only way I know to fix that is 1) buy a pair from somewhere else or 2) cut apart the probe so that you can solder the wire back to the tip, then epoxy the probe back together.
Re: Fusible links
Fatdog2:
Fatdog2:
The Guz
Dec 23, 2015 01:09 AM
sideways_Into_3rd
Feb 14, 2003 10:38 PM
