Fuel Pump won't shut off
Old Aug 14, 2006 | 09:01 PM
FNFAL308's Avatar
91 Firebird 305 TBI
Did search and found every other issue with fuel pump but this one.
No alterations of anything on car - stock. Changed fuel pump about year ago.
Changed oil today and cranked it to let oil get flowing. Shut it off and fuel pump kept running. Disconnected battery and reconnected and the fuel pump started back up. Figured it was the relay so I changed it - same thing. Right now I have the fuse out of it (by the battery).
Any ideas why the fuel pump would stay on?
Thanks for the help.
Doug
Old Aug 14, 2006 | 09:38 PM
davidarel's Avatar
Re: Fuel Pump won't shut off
Sounds like your oil pressure sending unit. The fuel pump runs through this so if there is a failure, the pump will shut off and the motor will not keep running. This is actuall a common problem.
Old Aug 15, 2006 | 06:23 PM
FNFAL308's Avatar
It worked ok when I shut the engine off at work today. Thought I was going to have to change the ign switch.
Scottyboy
Feb 11, 2015 10:28 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
