fuel pump
Old Jan 17, 2006 | 07:20 PM
blazzinbird's Avatar
fuel pump
I am looking for a fuel, I am looking at the racetronixs kits here are my 2 options
Racetronix Fuel System w/ 255 LPH High-Pressure Fuel Pump and Series II Plug-&-Play Wiring Harness (includes chassis ground & booster pump plug-&-play option), LT1 F-body $249.95
Racetronix 255 LPH High Pressure Fuel Pump Assembly, in-tank wiring & installation hardware, LT1 F-body $160.00
which should i get, i have 42# injectors
Old Jan 17, 2006 | 07:47 PM
2000GTP's Avatar
Re: fuel pump
I didn't read enough convincing feedback in order to purchase the 90.00 harness, so I went for option B and just bought the pump by itself. The nice thing though is Thunderracing sells both the harness and pump seperately or as a kit so if the need for the harness comes up in the future, then I can always get it then.
Old Jan 17, 2006 | 08:05 PM
camaroz28_97's Avatar
Re: fuel pump
I have the Racetronix Fuel System w/ 255 LPH High-Pressure Fuel Pump and Series II Plug-&-Play Wiring Harness (includes chassis ground & booster pump plug-&-play option) It works great. One of the few mods i have done to my car that had 0 side effects
Old Jan 18, 2006 | 05:04 PM
Re: fuel pump
what is the extra harness for?
Old Jan 19, 2006 | 04:58 PM
2000GTP's Avatar
Re: fuel pump
The Racetronix harness basically provides a direct connection from the alternator to the fuel pump which results in a greater voltage supply as compared to the factory wiring harness.
Old Jan 19, 2006 | 06:19 PM
OBE1 95Z28's Avatar
Re: fuel pump
You can read up on the wiring benefits on the Racetronix site; basically besides a higher voltage source from the alternator, the larger gauge wire reduces voltage loss over the length of the wire (back to the fuel pump).
A fuel pump's output is directly related to the voltage it's being run at. They're output rating is based on 12V, if you're seeing less that 12V due to voltages losses, the pump's not going to generate the same output.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
