Fuel pump?
Old Nov 3, 2005 | 01:21 AM
Big_TA's Avatar
Fuel pump?
I think my fuel pump went. The reason is because it wont really run unless i'm giving it gas. I put it in about 3 years ago but never drove it oin the winter. Does anyone know how to tell if it's the fuel pump or not? Thanks
Old Nov 3, 2005 | 06:47 AM
RE AND CHERYL's Avatar
Re: Fuel pump?
Check the fuel pressure
Old Nov 3, 2005 | 04:19 PM
Big_TA's Avatar
Re: Fuel pump?
This might sound dumb but what do I need to do that?
Old Nov 4, 2005 | 10:22 PM
mattbailey's Avatar
Re: Fuel pump?
You have a shradder(sp) valve on the fuel rail at the rea passanger side. Get a fuel pressure tester, take off the cap to the shradder valve, screw in the pressure tester, then turn on the key.
Old Nov 6, 2005 | 01:15 PM
OBE1 95Z28's Avatar
Re: Fuel pump?
Checking your fuel pressure will tell you whether your fuel system is working properly. You don't want to replace your fuel pump if it's working properly.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
