Engine got wet, now pings
Old Jul 25, 2004 | 08:18 AM
two converts's Avatar
Hi Guys,
I power washed the engine in my 94 Z28 yesterday, I took it for a ride and everything was fine. This morning I started it and it was missing, I let it warm up and the miss went away. When I initially hit the throttle it pings (like spark knock) but when it gets above idle it now runs smooth and revs fine.
What did I get wet and what do I need to do???
Thanks! Ralph
Old Jul 25, 2004 | 09:45 AM
Steve0's Avatar
Re: Engine got wet, now pings
You got your optispark wet. The optispark is a distributor mounted on the front of our engines that uses and optical sensor to keep track of timing. Moisture can prevent the optical sensor from reading accurately, and cause misses.
If youre lucky, just give your car a few days to dry out. If it doesnt dry out, your distributor will have to be replaced.
Next time you wash down the engine, try to avoid getting the front wet.
Old Jul 25, 2004 | 01:32 PM
Great, thanks! If I have to get to it does anyone have instructions or pics to lead me in the right direction???
Thanks, Ralph
alphaauto
Jan 23, 2015 07:42 AM
Noenav
Dec 6, 2014 07:35 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
GigaMp3z
Feb 20, 2003 02:57 PM
