edel pro flow air filter
Old Apr 24, 2011 | 11:15 AM
leadmonster's Avatar
ok so i got the camaro going finally and put a pro flow foam filter on and went for a cruise. about half throutle it starves out. ive used the pro flow on 350ci befor with no probs. i guess for a big block its just not enough. they say it flows 1000cfm. i must be missing something.
Old Apr 24, 2011 | 12:53 PM
Re: edel pro flow air filter
Without knowing the details of your "big block" it's very hard to comment? Displacement? flywheel HP? Normally aspirated?
A number such as "flows 1,000 cfm" is totally meaningless, unless it is accompanied by the pressure drop they used when they measured the flow. They would also have to state whether its ACFM or SCFM corrected to some standard conditions.
Old Apr 24, 2011 | 01:48 PM
the filter im talking about it the triangle shaped one with the foam incert. when i read that they flowed 1000cfm i figured it would be ok to use. thats all the info i seen. i cant seem to find where i read it though. my engine is 468ci some mild head work team g single plain. 10.2:1 comp . dont know what my power out put it yet but it would be nice to know . i can open it up when i take the air filter off so. my only issue with this set up is deciding how to do the intake. if i put a 4in tall k&n filter on then ill have to use a 6in tall hood scoop. my concern is visibility on the road.
Old Apr 24, 2011 | 02:23 PM
If you run it temporarily without the air filter element, does it still "starve out" at half throttle and above?
Old Apr 24, 2011 | 02:44 PM
nope. thats how i know its the filter. been looking for info on it but nothing. oh well. guess ill have to use a drop base 4in air cleaner. the carb sticks out 2in above the hood. hopefully that will let me use a 4in hood scoop.
Old Apr 25, 2011 | 12:02 PM
redneckgames's Avatar
Is this the filter you are using?
If it is, they are terrible! They will start to fall apart and all that black foam material gets sucked into the engine. Plus if you happen to backfire through the carb, the foam tends to catch on fire.
This is from experience. I bought a 84 z28 with one of those on it.
Old Apr 25, 2011 | 07:31 PM
yep thats the one. yea i had those problems with it befor . figured this time would be diffrent lol. but yeah i found where i read that it flows 1000cfm. the may-june summitt mag. must just be a typo... if i cant open up a 750 holley with it on.
PCLZ28
Dec 24, 2015 05:19 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
kksi
Mar 21, 2015 09:03 PM
Jazsun
Dec 29, 2014 12:14 PM
