crash door bar removal, how did you get it out???
Old Nov 16, 2005 | 03:44 PM
sniffin94's Avatar
I have a 10 point cage in the car and I did a search that didn't return anything. How the hell do you get to the front 2 bolts to get the crash bars inside the door out. I got the 2 by the door handle out but for the life of me I can not think of how to get the front 2 out. I took a 10mm socket and ground it down to almost nothing. Just enough to catch the bolt and it worked until the ratchet (which is the skinniest 1/4" I could find) started rubbing on the doorskin. I haven't found any tool to catch the other one. What did you guys use to get it out??
thanks
Old Nov 17, 2005 | 12:09 PM
Z28SORR's Avatar
Re: crash door bar removal, how did you get it out???
Sounds like this is installed before the door skin is glued on. May have to cut it off.
Old Nov 17, 2005 | 04:19 PM
sniffin94's Avatar
I know people have gotten the bolts out. I am at the end of my rope. I think the dremel is going to come out on Sat
Old Nov 17, 2005 | 07:22 PM
TraceZ's Avatar
That is correct. I removed one once, and it required removal of the door skin.
Old Nov 18, 2005 | 05:29 AM
FuryZ28's Avatar
How much do those things weigh? Just curious if it's really worth the effort...
Old Nov 18, 2005 | 08:39 AM
TraceZ's Avatar
I dont recall the weight. I was creating documentation at the time showing the inner guts of the door and had to remove the skin and crashbar to get a clean camera shot.
The whole mess went in the garbage when I was done. Sorry i dont still have it, or I'd weigh it for you.
Old Nov 18, 2005 | 09:38 AM
FuryZ28's Avatar
Any rough guess per door? 5 lbs.? 10 lbs.?
Old Nov 18, 2005 | 09:53 AM
TraceZ's Avatar
I dont recall them being particularily heavy. Maybe 5 lbs each?
Old Nov 18, 2005 | 10:02 AM
FuryZ28's Avatar
Hmm, may be something I consider in the future, when I'm really hunting to shave pounds...
Old Nov 18, 2005 | 05:02 PM
sniffin94's Avatar
both crash bars by themselves were something like 16.8 pounds (off of a friends car.) The dremel will be in action tomorrow
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
R@mpage
Apr 20, 2015 10:02 AM
siguy
Nov 27, 2014 10:07 AM
