changing plugs
Old May 29, 2004 | 02:16 AM
min9861's Avatar
changing plugs
is it ok to use platinum plugs for my car?93z28. the guy at pepboys said somthing about putting anti-seize on the plug before i install em. ty
Old May 29, 2004 | 02:56 AM
coogsLS1's Avatar
yep and yep but stay away from bosch platinum. go with ngk.
Old May 29, 2004 | 03:19 AM
aforut's Avatar
You definetely want anti-seize so next time your change them you won't want to drive the car off a cliff!
Old May 29, 2004 | 03:26 AM
97WS6SCharged's Avatar
Too bad there's no cliffs in Gainesville.
Old May 30, 2004 | 12:24 PM
OBE1 95Z28's Avatar
You just need a very small amount of antisieze on the plug threads.
Old May 30, 2004 | 10:13 PM
Bud M's Avatar
Yes its okay. The OEM plugs are ACDelco platinum. Use anti sieze.
Old May 30, 2004 | 10:31 PM
DonHood's Avatar
I changed all 8 plugs/wires without removing a single engine accessory. Only tools I used were a socket wrench, 3" extension, and a plug socket. I did it like that mainly just to see if it could be done, but I won't do it like that again.
Words of advice:
The #2 plug will make you want to do bad things to people. All of the wires on the passenger side will make you want to do bad things to the car.:blah:
Old May 31, 2004 | 01:41 AM
min9861's Avatar
i couldnt get to the 4th plug so i had to jack up my car and get it from under the car. pain in the ***.
Old May 31, 2004 | 08:46 PM
n2ceptor's Avatar
Do you mean #8 on the passenger side, or #7 on the driver side
I can get all of mine from the top, with stock manifolds and I have'nt had to anti-sieze..
Old Jun 1, 2004 | 01:26 AM
EaC95Z28's Avatar
hey can you include some details on how you do this. getting all of them from the top with the stock manifolds. thanks lmk.
Old Jun 1, 2004 | 08:19 AM
n2ceptor's Avatar
Cylinders 1-6, I use 5/8 spark plug socket, three inch extension, and universal socket..
Cylinder 7 & 8, 15 inch extension with universal socket..
Number 8 is a pain, but I am able to slide my arm down the side, ( using a kevlar sleeve jeg's # 856-39024 ) to extract the plug....
PCLZ28
Dec 24, 2015 05:19 PM
captcorvette
Mar 7, 2015 12:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
