can I remove ac from my camaro?
Old Dec 3, 2009 | 10:45 PM
99firehawk#312's Avatar
I have a 1995 camaro z28 I am rebuild the motor ac is no good and I want to do away with the ac compresser just dont know please help?
P.S I am going to put a cam in the lt1 how big can I go with out change chip,computer it is a 6 speed car?
Bill
Old Dec 3, 2009 | 11:29 PM
MikeGyver's Avatar
You can get an A/C delete pulley and remove the entire system. Email CompCams about your cam question.
Old Dec 4, 2009 | 05:13 AM
Installing a more aggressive cam without a custom flash tune (no chip in your 95) is a waste of money. You can pick up 10-15HP with a tune on a stock cam/stock engine. Install a cam without tuning it, and you leave HP on the table and will probably have drivability issues.
Old Dec 5, 2009 | 10:16 AM
99firehawk#312
Why did you "report this post"? Did you mean to hit "reply", and hit "report" by mistake?
99firehawk#312 ( mailto:billandmarie.1@netzero.com ) has reported this post:
https://www.camaroz28.com/forums/sho...74#post6191774
This is part of this thread:
https://www.camaroz28.com/forums/sho...d.php?t=725030
This is the reason that the user gave:
is it a pulley that go in it place ? do you have a web site? thanks
This message has been sent to all moderators of this forum, or all administrators if there are no moderators.
Please respond to this post as applicable.
If you meant to ask about the AC delete pulley, yes, this is the pulley that was used in place of the AC compressor, on the 1LE models that did not have AC. You can get them from several sources, but a GM part is going to be more reliable. Shoebox has the part # on his website:
http://shbox.com/1/Parts.htm
97SSdude
Dec 31, 2014 07:43 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
Jul 4, 2005 05:00 PM
