brake light on
Old Sep 11, 2016 | 04:06 PM
95LT4Z28's Avatar
brake light on
i did an ABS delete and my brake light stays on. if i pull the abs fuse the light goes off but the brake light does not light when i pull up my emergency brake up . any ideas?
Old Sep 11, 2016 | 04:39 PM
Re: brake light on
The "BRAKE" light can be activated by three sources:
1 - E-brake switch
2 - Combo (differential pressure) switch on side of the ABS hydraulic modulator assembly (motor pack).
3 - certain faults detected by the EBCM (electronic brake control module) cause it to turn on the light from pin B4 of the EBCM.
Did you leave the EBCM in place? If so, pull the harness connector C2 off. Odd that pulling the ABS fuse turns the light off, preventing the E-brake switch from working. The 1995 factory schematic for the "BRAKE" light (the file attached below) shows the light gets 12 volts from "GAGES" fuse #9 in the instrument panel block. The E-brake switch, the Combo valve, and the EBCM pin only supply a ground to turn on the light.
Courtesy of Shoebox:
http://shbox.com/1/ABS_schematic.jpg
File Type: pdf
Old Sep 11, 2016 | 04:47 PM
95LT4Z28's Avatar
Re: brake light on
i removed the ecbm completly. all the plugs are just laying on the side. e brake light worked before i did the delete.
Old Sep 11, 2016 | 11:10 PM
Re: brake light on
So.... you removed BOTH the EBCM and the the ABS motor pack with the combo valve attached to it?
Old Sep 12, 2016 | 05:21 AM
95LT4Z28's Avatar
Re: brake light on
yes - removed the complete unit ---
al
Old Sep 12, 2016 | 10:45 AM
Re: brake light on
al
There are 2 "units". The EBCM is not the same as the motor pack/combo valve. It is located inside the passenger compartment, above the driver's side kick panel.
Maybe you removed that, but it isn't clear from your response. And if it isn't removed, or at least unplugged, it would explain why your light is staying on.
Old Sep 12, 2016 | 11:04 AM
95LT4Z28's Avatar
Re: brake light on
i removed the motor pack / combo valve. did not remove the ebcm. i will un plug it. will let you know . thanks
Old Sep 12, 2016 | 11:45 AM
95LT4Z28's Avatar
Re: brake light on
just looked at that EBCM. there is one small plug and one large plug with a lot of wires. will unplugging them affect anything else in the car? have not done it yet
Old Sep 13, 2016 | 05:01 PM
95LT4Z28's Avatar
Re: brake light on
pulled the two plugs and the brake light is not on and the e brake light is working again. thanks
Old Sep 13, 2016 | 10:40 PM
Re: brake light on
Glad it worked out for you.
95LT4Z28
10
Feb 22, 2018 05:58 PM
real82it
Sep 24, 2016 08:00 AM
gingy1987@hotma
Aug 16, 2016 04:47 PM
Ronney13
Aug 13, 2016 09:42 AM
rick0312
Jun 25, 2016 08:24 PM
