Alternator bolt comes loose
Old Feb 10, 2015 | 01:18 PM
moparman's Avatar
Car is a '96 Formula. The bolt that connects the red power line to the back of the alternator keeps backing out. Of course when this happens no chargee. Is it safe to use thread locker on the bolt, or this there another fix?
Old Feb 10, 2015 | 03:37 PM
Re: Alternator bolt comes loose
Can't remember.... is there enough thread to double-nut it?
Or is the stud backing out of the alternator?
Old Feb 10, 2015 | 04:12 PM
moparman's Avatar
The stud appears to be all thread with a nut. I might be able to get another nut on it. Was wondering if thread locker would interfere with conductivity.
Old Feb 10, 2015 | 04:42 PM
Yes. The eyelet on the wire produces maximum contact with the sides of the nut. If you insulate the nut from the stud, it would seem that significant conductivity could be lost. They make "thin" jam nuts, so that might help if there is only a couple threads available. Or two thin nuts?????
Old Feb 10, 2015 | 06:39 PM
moparman's Avatar
A lock washer might work.
It's not the nut coming loose from the bolt. The bolt itself comes loose from the alternator. Unscrews itself in some fashion.
Old Feb 10, 2015 | 09:27 PM
Use a prevailing torque nut (e.g. aircraft nut). One with a plastic insert or swaged edge.
Google it. You'll see examples.
Old Feb 10, 2015 | 10:10 PM
GaryDoug's Avatar
Prominent Member
Threadlock would be ok there. And/or a lock washer. But the stud or alternator may be stripped or worn too badly to stay put. Can you tighten the stud to the recommended tightness (about 10 lb-ft)?
Another possibility is that the cable is too tight and pulls on the stud, turning it with vibration.
Now that I read again... "all thread with a nut". Does that mean there is no shoulder between the nut and the alternator? You may have the wrong stud there.
Old Feb 11, 2015 | 08:29 AM
I misread, earlier. You need to open up the alternator and secure or replace the stud.
Victor Lamb
Aug 26, 2017 02:52 PM
KYWes
Apr 3, 2015 07:59 PM
maybe2fast
Mar 16, 2015 09:45 AM
Red97LT1
Mar 1, 2015 05:08 PM
