96 z28 factory alarm system
Old Jan 10, 2020 | 07:13 AM
numbr44coldcuts's Avatar
I believe my car has the optional factory alarm system installed. Is there information on how to remove it? Its too easy to set off when I get into the car.
Old Jan 10, 2020 | 10:00 AM
peterpar's Avatar
Re: 96 z28 factory alarm system
According to the 1996 Service Manual, if you lock the doors with the inside door switch, the alarm will not set. I think that would be a much simpler task than trying to remove the system.
Old Jan 10, 2020 | 11:20 AM
If it is the optional factory alarm system, you should have RPO "UA6" on the Service Parts Identification label.
The info in the post above above is the simplest.
System operation is described in the 1996 Owner's Manual, Page 2-13. If the problem is caused by the shock alarm being too sensitive, the shock sensor can be adjusted to be less sensitive. You can also select passive or active initiation of the alarm system. If you don't have an Owner's Manual, you can access it here, and download a pdf:
https://my.chevrolet.com/how-to-support/manuals
It is not necessary to set up an account.
Additionally, there is detailed info in the factory service manual, as mentioned in the post above. Free download of manual here:
http://www.mediafire.com/?40mfgeoe4ctti
See Book 1, Part 2 of 2, Section 9D.
Old Jan 10, 2020 | 02:03 PM
Thanks for the responses. I suppose it isn't necessary to uninstall the alarm system if its adjustable.
awill12
Apr 30, 2012 03:00 PM
Z28Lightning17
Nov 29, 2010 07:07 AM
henryz28
Oct 21, 2008 06:53 PM
cmw214
Aug 16, 2005 07:56 PM
johnnymg
Mar 18, 2003 08:44 PM
