1995 3.4 V6 won't crank
Old Feb 29, 2016 | 03:29 PM
  #16
tehhijack's Avatar
Re: 1995 3.4 V6 won't crank
I found out there are fusable links next to the battery so i will check those next before investing in new coils. I'll be back with the results. Thanks for the advice injuneer
Old Feb 29, 2016 | 05:26 PM
  #17
tehhijack's Avatar
Fusable links all checked good with a continuity test. I tried jumping the starter with a screwdriver and it turned but i think i positioned wrong because i heard a gear grind a a little so i'll have to take it back off and reposition it. Still will not crank. are there any hidden starter relays somewhere? I checked under the hood and in the interior fuse box and could not find one.
Old Feb 29, 2016 | 08:52 PM
  #18
The theft deterrent relay (TDR) is between the ignition switch and the starter. If the theft deterrent module (TDM) gets the correct resistance from the key, it sends a ground to the TDR to activate it. The TDR is located to the right of the glove box, attached to the metal structure of the dash.
All this comes from a "how to" at shbox.com
Click on "Tech Page"
Click on "How To's"
Scroll down to #25.
Old Feb 29, 2016 | 10:37 PM
  #19
tehhijack's Avatar
That was the guide i used to bypass the VATS with the resistor. I will take out the TDR tomorrow and switch it out with another one. I will report back with the results.
Old Mar 1, 2016 | 12:41 AM
  #20
tehhijack's Avatar
I just jumped the yellow and purple wire and nothing.... I will check for power on the yellow wire tomorrow, it is getting late. When i turn the key the "low trac" light flashes, would that be something that would prevent it from starting? I know the low trac is something with the ABS. My ABS wires that go to the wheels were cut for some reason by the previous owner. I will see if i can get another neutral safety switch, maybe that is what's causing all of this.
Old Mar 1, 2016 | 07:01 AM
  #21
tehhijack's Avatar
I do not have 12v going to the yellow wire on the TDR, i do however have 12V on the red wire from the ignition switch. Where does the yellow wire come from? I am hoping all of this is just a loose connection somewhere. I am getting power to the starter, if i jump the small purple wire to the big wire it cranks.
Old Mar 1, 2016 | 09:14 AM
  #22
tehhijack's Avatar
Another $22 down the drain. Replaced the TDR and still no crank
Old Mar 1, 2016 | 02:07 PM
  #23
Shoebox:
http://shbox.com/1/pass_key.jpg
http://shbox.com/1/ignswschematic.jpg
Yellow wire at TDR comes from the ignition switch "start" position
The only red wire at the ignition switch is the red wire that supplies 12V to the ignition switch. That comes from one of the fusible links. The circuit splits before the ignition switch, and also supplies the RAP module and the I/P fuse block.
Old Mar 1, 2016 | 02:13 PM
  #24
Originally Posted by tehhijack
It drops down to 11.95v while turning the key to crank, nothing happens. I asked around and they hinted to my coil packs being bad since i put a brand new battery in and the coils are probably OEM and they blew because they were old.
Where did you measure 11.95 volts? If it was at the battery terminals, it is not necessarily the same as what the dash gauge would show. And there's no way you could determine that the gauge read 11.95 volts.
Somehow I don't think the 12 volts from the battery is reaching the starter. Is it possible when you crimped on the new battery terminals, there was wire insulation in there that is isolating power to the starter, or even reducing the area of metal contact to the point where as soon as the starter attempts to pull a couple hundred amps, the voltage drop seriously?
Old Mar 1, 2016 | 08:12 PM
  #25
tehhijack's Avatar
I measured the 11.95 volts at the battery terminals while cranking. I stripped the insulation about an inch back on both sides and used a big crimp? or whatever it's called. If you think that might be the issue i can cut it off and solder the connection.
Old Mar 2, 2016 | 01:02 PM
  #26
tehhijack's Avatar
Soldered the cables and no change. A friend of mine said the same thing happened to him when he tried extending the cables, replacing them with a single cable solved his problem. I am thinking that might be my issue. It's worth a try seeing how ive tried everything in the book.
surreybrad
Apr 22, 2015 06:40 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
k1996z28
Apr 13, 2015 06:54 PM
FredM
Apr 10, 2015 02:56 PM
