1988 Iroc Cooling Fans
Old Feb 22, 2020 | 10:49 AM
TrexNoDen's Avatar
I have an 1988 Iroc Camaro with the 5.7 350 V8 in it. If my research is correct this camaro came from the factory with the duel cooling fan set up. The main fan is supposed to be controlled by the ECM and come on at 230 degrees while the secondary fan is controlled by the A/C and comes on at 238 degrees. One of the previous owners took it upon themselves to redo the radiator fans in an interesting way. This camaro no longer has the A/C and has a delete pulley in it's place now. As for the fans, I can't tell if they are original of after market fans but they are wired directly to the battery and have wires running to the dash board on two separate switches with no relays in the system so the switches get to hot to touch after about a minute. I believe i have found the original wires for the fans all cut off and wire nutted together. Is there a good AC kit out there to add the AC back in as well as a harnessing kit to fix and/replace the harness for the dual fans?
I have attached pictures of what I believe is the old fan harnessing and where the AC should be. Any help or advice is appreciated.
What I believe is the Original wiring for the fans
Missing AC
Don't know if after market
Old Mar 11, 2021 | 12:32 AM
BozzIROCZ's Avatar
Re: 1988 Iroc Cooling Fans
Sorry to tell you but thats a bad hack job without original parts, the fan shroud on the IROC covers the fan blades those are 2 of the same blades, the fan shroud also covers the back of the rad and pulls air from the front air dam under the car to cool off the rad, by looking at it it seems like those are fans from a z28 5.0
Old Mar 11, 2021 | 12:57 PM
TrexNoDen's Avatar
Do you know where I can get the right parts to try and bring it back to original?
Old Mar 11, 2021 | 02:06 PM
BozzIROCZ's Avatar
Are you in Canada or the states?
In Canada you can call a buddy of mine in Thamesford Ontario company name Redline, he will send you whatever you need. In the states first place I would look is Rockauto but I personally get all my parts from Summit Racing, they have OEM parts. If you need any help let me know at noymfbja@hotmail.com I'll get you whatever info you need about these cars, mechanical, electrical, vacuum, suspension interior or anything, if I cant find it, it doesnt exsist.
Old Mar 11, 2021 | 03:07 PM
DrewHMS97SS's Avatar
Hawks motorsports has a ton of old stuff. You can also try Classic Industries.
Old Mar 11, 2021 | 04:50 PM
BozzIROCZ's Avatar
Agreed but I find Hawks is a bit pricy for shipping, I'm trying to save the guy some dough Summit Racing has free shipping over $100.00
Old Mar 11, 2021 | 06:21 PM
His profile shows he is in the U.S.
Old Mar 12, 2021 | 06:21 AM
It is more expensive than free. What I can say is that their website does not do well at estimating shipping across multiple parts. They have been good to me on refunding excess shipping costs once the items are packed.
Old Mar 16, 2021 | 12:59 AM
BozzIROCZ's Avatar
Thats ok, but I've been dealing with summit racing since the 1980's, have never had a problem with their returns, but if an order has not been correct it was because I ordered the wrong part, and even so summit never cared they help me return it for the right part, they even sent me the part that I needed with only my word of return info from the post office.
lawmanz28
Apr 7, 2009 10:56 AM
ryan88z
Oct 8, 2007 08:52 PM
mscott3
3rd Gen / L98 Engine Tech
May 23, 2006 11:49 PM
toegead93
Jul 11, 2005 09:46 AM
irocz8957
Apr 14, 2003 02:07 PM
