Help With Fans Please
Old Oct 8, 2007 | 05:27 PM
ryan88z's Avatar
I bought my 95 z lt1 a little while ago . The fans were hooked directly to the battery . so i went yesterday and got all 3 relays new ..If i put the ac on . the fans come on no problem. when the car sits and idles without the ac i cant get the fans to come on .. I thought maybe it was the temperature sensor so i replaced that and nothing. got my haynes manual out. relay 1 and 2 seems to have power on the wrong terminals for the relays. could it be a bad computer or maybe someone programmed it wrong? Any help would be very appreciated. thank you .
ryan
Old Oct 8, 2007 | 06:33 PM
You don't say what temp you are waiting for to say "the fans don't come on". 226° is the factory ON programming for low speed. More fan and cooling system info here.
Old Oct 8, 2007 | 06:55 PM
ryan88z's Avatar
Temp got up to 230 before i turned the ac on to get the fans running
Old Oct 8, 2007 | 06:58 PM
The dash gauge may not be completely accurate. Monitoring with a scanner is a better way to tell the temp the computer sees.
Old Oct 8, 2007 | 08:52 PM
ryan88z's Avatar
thanks . im thinking either a bad wire from the sensor to the pcm. im thinking the same thing about the pcm not reading the right temperature. gotta find someone with a scanner first . thanks for your help
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
