LT1 Cooling Fans
Old Mar 23, 2009 | 11:43 AM
lawmanz28's Avatar
LT1 Cooling Fans
I have a 1996 Z28-SS 6-speed. I was in the process of installing a manual fan switch and I have realized that the fan on the drivers side would not work in low or high speed. If i cut the ac on both fans come on. I have tested all three relays and have tested the wiring from the relay to that fan. I was wondering if some one could tell me which fan is supposed to come on at which temperature and which fan or fans come on with the ac.
And if someone could tell me where the cooling fan relay controls are at.
Old Mar 23, 2009 | 12:08 PM
http://shbox.com/1/4th_gen_tech2.html#cooling
Old Mar 23, 2009 | 04:42 PM
lawmanz28's Avatar
Thanks for that info shoebox. You wouldn't happen to know where the relay control is for both the 1st relay and the one for the 2nd and 3rd relay. I am pretty sure that the fans are not working properly on their own with the exception of using the ac to turn them on.
Old Mar 23, 2009 | 06:24 PM
The computer is the "relay control".
Old Mar 25, 2009 | 06:13 PM
lawmanz28's Avatar
ow well that makes since, thanks. and i have got another problem on the manual fan switch i bought on the green wire where the led wire and the wire to the switch connect was getting hot and burning the heat shrink. i thought there might be a short so i took off the heat shrink and found a resistor either a 47 or a 41 ohm ( i could not tell if the second band was violet or brown) and it was comming from the green wire. that is what is actually getting hot and there is not a short like i originally thought. i can tell that there is resistors at the leds but i do not know what this resistor is for
Old Mar 25, 2009 | 06:33 PM
Probably designed like this.
Old Mar 25, 2009 | 08:32 PM
lawmanz28's Avatar
yeah thats it. but why is the resistor heating up. and i still have not figured out why the driverside fan is not working ( except with the ac)
Old Mar 25, 2009 | 10:21 PM
Maybe there is a problem with the wiring.
Old Apr 6, 2009 | 12:22 PM
lawmanz28's Avatar
is that two 47 ohm resistors in parallel on the blue high wire side? and thanks for all the info
Old Apr 6, 2009 | 12:49 PM
That is correct.
Old Apr 7, 2009 | 09:49 AM
lawmanz28's Avatar
does the computer control the fans when you turn the a/c on or is there another way
Old Apr 7, 2009 | 10:20 AM
The computer controls the fans in all situations.
Old Apr 7, 2009 | 10:56 AM
lawmanz28's Avatar
I HAVE JUST FIGURED IT OUT!!!! I saw on this forum about just grounding the wire to see if the fans work well i did that with the car running and i heard a snap and the car cut off. the ignition fuse was blown so i looked at the plug in the stupid kit and he had taped into G instead of J at the C100 plug. I was on my way back to work but now i am stranded, luckley a friend lives near by and can take me to autozone for some fuses.
ChrisFrez
Jan 18, 2015 08:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Jul 4, 2005 05:00 PM
IrocSS85
Jul 18, 2002 10:35 PM
