‘00 Z28 Bent Axle. Replaced shaft but still rubs. Bent backing plate?
Old Oct 9, 2022 | 03:16 PM
LS_Juan's Avatar
Awhile back I hit a curb with the rear tire. The wheel was busted and the end of the axle shaft was bent. I replaced the axle shaft, wheel and rotor but the pads still rub the rotor. Prior to replacing the axle shaft the rotor came into contact to the point where you couldn’t spin it by hand. With the new axle you an turn it but you can hear it rubbing. When I look at the tire when it’s off of the ground I think it looks pushed inward on the bottom so I’m thinking maybe the thick metal part of the backing plate is pushed inboard at the bottom. Would y’all take a gamble on a new backing plate? They are on the expensive side used and I haven’t found a new one other than Hawk’s set for $300. Or is it more than likely that the brakes will still rub and that I need a whole new axle assy?
I’ve messed with it so much that I think that I’m going to need a new caliper too. I can’t get it tightened down to the bracket anymore. Even if I hold the bushing on the slide pin so it doesn’t spin the caliper is still loose when the bolt bottoms out. I’m in a pickle.
Old Oct 12, 2022 | 09:47 AM
Re: ‘00 Z28 Bent Axle. Replaced shaft but still rubs. Bent backing plate?
Have the entire rear axle assembly checked for damage/misalignment. Whole thing might be bent up if you hit that hard.
Old Oct 14, 2022 | 05:54 PM
LS_Juan's Avatar
My worst nightmare.
Old Oct 14, 2022 | 09:08 PM
LS_Juan's Avatar
If it turns out that I need a whole new rear would you go used or reman? EBay has a low mile oem for something like $1100 shipped and remans run around $2k shipped. The scariest part about the reman for me is that it doesn’t specify which differential it has, and I’d like to have the Toresen. The old used one would probably need new seals and at minimum. A 12 bolt would be on but $2k is already on the way high end.
RacingTiger04
Jan 9, 2007 11:12 AM
Cmr0z28
Dec 12, 2005 02:19 AM
SpoolinV8ETR
12
Jul 4, 2005 09:56 PM
acayson
Dec 15, 2003 10:19 PM
SweetZRag
Advanced Tech
Jun 2, 2003 09:50 AM
