Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Would optispark misfire change based on temperature?
Old Dec 8, 2010 | 06:51 PM
Kurt Crosbie's Avatar
My engine fires fairly decent until it gets warm, then once it gets warm definitely is not firing on all cylinders. From my experiences with other cars, I would assume that a plugwire has gone bad, but my friend insists its the optispark. Would the optispark be temperature dependent just like the plug wires?
Sent from my ADR6300 using Tapatalk
Old Dec 8, 2010 | 10:29 PM
maddog05's Avatar
Re: Would optispark misfire change based on temperature?
Lt1 engines are apt to miss if the temp sensor in the water pump area is bad
Old Dec 9, 2010 | 05:21 AM
Heat soak problems can affect the IC module and the optical cam position sensor in the Opti.
Old Dec 9, 2010 | 08:53 AM
With that being said, it seems to me that it would be best to replace the optispark as well as the plug wires if I'm going to go in there at all.
DirtyDaveW
Dec 1, 2016 05:37 PM
PCLZ28
Dec 24, 2015 05:19 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jan 23, 2015 01:13 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
