Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Will the stock fuel reg go 1:1 for boost?
Old Dec 1, 2010 | 06:59 PM
TT350's Avatar
The plan is to run 10 PSI on a forged piston/rod 355 cid with the stock cam.
Can I leave the stock regulator?
Old Dec 1, 2010 | 07:14 PM
MikeGyver's Avatar
Re: Will the stock fuel reg go 1:1 for boost?
yes
The stock regulator will maintain a 43.5psi difference between whatever it sees on the vacuum port and the fuel pressure.
Old Dec 1, 2010 | 07:38 PM
TT350's Avatar
Thanks for the reply.
What are you guys getting away with as far as the stock fuel system is
concerned, lines,filter,regulator,fuel rails.
Excluding a pump or pumps to support the power goals.
I what a high 10 sec DD.
About 500-550 RWHP should be enough.
Old Dec 1, 2010 | 11:26 PM
You might want to read through the "High HP Fuel Systems - Q&A (4th Gen)" stickied on the Fuel and Ignition forum topic listing.
Old Dec 2, 2010 | 12:20 PM
rskrause's Avatar
Moderator
Still have mine supporting ~800rwhp.
Rich
DirtyDaveW
Dec 1, 2016 05:37 PM
canbaufo
May 25, 2015 12:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
LT1runner
33
Jul 24, 2002 01:19 PM
