Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Weak fuel pump?
Old Aug 13, 2015 | 05:27 PM
canuck94z28's Avatar
Weak fuel pump?
Hi.I,ve had a starting issue for yrs. on my 94 Z.I have to turn key on & count to 3& make sure i hear fuel pump cycle.Failure to do results in car not starting.I hooked up a fuel pressure gauge& got the following:44 psi,key on,pump running,45 psi(no vacuum),38 psi(14 in vac.),36 psi(motor running),37 psi(key on,engine off),Fuel pressure rose after a couple mins. to 44.I checked the fuel pressure reg.& it held pressure.I have a MSD Opti,MSD 6A,& MSD Coil(just installed).I have a MAF+ Translator & leaned out the fuel 2%& had rebuilt/flow benched 24 lb. inj. installedin 2013/14.Car has no drivability issues/high speed issues.Pl. advise& thnx for any advice..Darren
Old Aug 14, 2015 | 01:48 PM
Re: Weak fuel pump?
Are you saying that sometimes the fuel pump does not run when you turn the key to "run" and "start"? If so, have you checked the fuel pump relay?
Old Aug 19, 2015 | 05:50 PM
Re: Weak fuel pump?
Hi.Ty for the reply.I will ask the guy at the garage about that & update my findings.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
