Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
is there any difference between a fuel pump from a v8 car and a v6 car ?
Old Jan 9, 2022 | 04:28 PM
  #16
Re: is there any difference between a fuel pump from a v8 car and a v6 car ?
The entire sending unit is different.
The LS1 fuel pump unit has an internal bypass pressure regulator, sends the fuel at 58 PSI to dead-ended fuel rails with no return flow, and no vacuum compensation.
LT1 sending unit simply sends unregulated pressure fuel to recirculated rails, a vacuum compensated fuel pressure on the return line, maintaining 43.5 PSI at the rails, minus intake manifold vacuum.
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
USAirman93
Nov 24, 2014 03:37 PM
Skull Leader
Aug 10, 2002 11:01 AM
