Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
In-tank fuel pump
Old Jan 2, 2011 | 11:36 AM
TitoPR221's Avatar
In-tank fuel pump
Installed a Racetronix kit in my 95 T/A. Beware, if the pump does not fit the canister, Racetronix will not acknowledge the problem and will ask for the canister and pump for inspection and installation. I posted the problem in their forum and the post was deleted. I carefully sanded the canister nozzle using 120 grit and a socket cube until the pump fit. Customer service from Racetronix left a lot to be desired.
Old Jan 7, 2011 | 04:16 PM
Kevin Blown 95 TA's Avatar
Re: In-tank fuel pump
Welcome to 2001
There's been a lot of posts on this in the past,
Did the pump look different on the bottom than the one you had?
Old Jan 11, 2011 | 06:52 PM
TitoPR221's Avatar
Originally Posted by Kevin Blown 95 TA
Welcome to 2001
Significantly different, the stock pump has a rubber bushing, the new one has an o-ring.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
