Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
something causing ignition switches to go bad?
Old Jun 21, 2007 | 03:16 PM
FWBcut's Avatar
My problem first started when my car wouldn't start. The ding sound from the keys being in would be faint but then after a few seconds it would return to normal and the guages would light up. If I tried to start it the starter clicked and everything turned off. Then again after a few seconds gauges lit up etc. Seemed like an ignition switch problem, so I replaced it and everything worked like it should for a day. Now I'm back to where I was before. What could be causing the switches to go bad? And what wires are used to hot wire the car to start it so I can drive. My other car is 400 miles away and I need to get around. Thanks
Joe
Old Jun 21, 2007 | 03:57 PM
FWBcut's Avatar
Forgot to say it's a 95 z28 m6
Old Jun 21, 2007 | 04:36 PM
The main 12v power connector to the switch often gets hot and makes a poor connection at the switch. Did you check that?
Old Jun 21, 2007 | 08:24 PM
FWBcut's Avatar
Is this the black connector with one wire on it?
Old Jun 21, 2007 | 10:53 PM
It should have been real easy to spot. Most look like this.
Old Jun 22, 2007 | 01:38 AM
FWBcut's Avatar
Definitely don't have that problem. Anything else I should look for? Thanks
Old Oct 1, 2007 | 07:16 AM
Cool ZR's Avatar
Hey Shoebox,
What causes the switch to do that and is there a fix for it? I just replaced my second one in 6 years now...
Heathen1
Jan 2, 2016 04:27 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
