Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Secret 18 gal tank option?
Old Jul 24, 2020 | 05:01 PM
58pan's Avatar
Have had this 1995 Z28 about 9 mo. Was told by previous owner not to let it get below 1/4 or it will run out of gas.
Just had the pump/sending unit replaced, threw a can of gas in the back, and drove it till the gauge needle was covering the top of the E. Filled it up and it took 17.675 gal. The owners manual says it has a 15.5 gal. tank. Every where else I look says 15.5 gal. tank.
Is there a secret 18 gal tank option?
Old Jul 24, 2020 | 08:59 PM
Re: Secret 18 gal tank option?
The same steel tank was used in the 3rd and 4th Gens from 1982 up to 1998. All listed as 15.5 gallons. In 1999 they went to plastic and managed to squeeze a 16.8 gallon tank in the same space.
Maybe try a different station, with a current weights & measures certification sticker on the pump.
Old Jul 26, 2020 | 12:37 PM
JakeRobb's Avatar
Super Moderator
I’m with Fred — the most likely cause here is a faulty or miscalibrated meter on the pump.
mexicutioner
Jun 17, 2020 11:35 AM
Brents95Z
Oct 30, 2007 10:43 AM
VernsGirl
Sep 28, 2007 03:02 PM
TSMITH
Apr 21, 2007 09:10 PM
z28sinx
Jul 23, 2004 06:26 PM
