rusty gas tank
rusty gas tank
My 95 z28 has been sitting for a very long time with a bad fuel pump. Finally was able to remove the tank and inspect it. Total carnage! Pump is destroyed inside. There is a lot of rust and other debris inside. My question is what are some good techniques or products that may help me get this tank cleaned up from the inside. I've done a few rinse and drains on the tank itself with some detergent and vinegar and water mix. I also have a delphi tank cleaning kit, but didn't want to use it right away due to the large amounts of debris inside. Let me konw. Any input is appreciated.
Re: rusty gas tank
FWIW, I believe this problem is caused by ethanol-gas, and the water that it holds in suspension. As for prevention, you can buy non-ethanol gas from a surprising list of sellers, but not the cheap-gas folks at the corner convenience store. Premium not-ethanol may still be scarce, and if pennies per gallon will change your choice of gas stations, this option is not "realistic" for you. Non-ethanol gas typically costs about a quarter-dollar more per gallon, but maybe you won't be changing out gas tanks in a few years. Find non-ethanol locally:
https://www.pure-gas.org/
HTH.
Re: rusty gas tank
There's a member here who swapped a factory plastic tank from an LS1 F-Body into an LT1 F-Body:
https://www.camaroz28.com/forums/lt1...l-tank-886314/
Re: rusty gas tank
I managed to clean it up decently. But the time and effort spent probably are not worth the price of a replacement tank. I'm happy with the result but something to consider to those having similar issues.
now to figure out the evap canister lines that I didnt take note of before my son removed them.
Brents95Z
Oct 30, 2007 10:43 AM
